1. kegr1978's Avatar
    When I'm on calls my Samsung Galaxy S5 opens several menus when my cheek touches the screen...this used to never happen, startes about a month ago, I believe my proximity sensor button is turned on, what else could it be?
    12-05-2015 10:31 PM
  2. srkmagnus's Avatar
    You mean the proximity sensor is broken? The screen should be turned off whenever the device is close to your face. You can try clearing cache through recovery o see if that helps: power off. Hold home+volume down+power on until recovery loads. Use volume down to clear cache and power to accept. If that doesn't fix the problem then try a factory reset - be sure to backup your data first.
    12-05-2015 11:33 PM
  1. Replies: 1
    Last Post: 12-15-2015, 09:42 AM
  2. How can I reinstall my Samsung Galaxy drivers on my computers?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 12-15-2015, 09:36 AM
  3. battery pack with built in USB C
    By ezzzzz in forum Nexus 5X
    Last Post: 12-08-2015, 10:46 AM
  4. I forgot my password on my Irola
    Last Post: 12-06-2015, 12:03 AM
  5. Replies: 0
    Last Post: 12-05-2015, 10:11 PM
