1. AC Question's Avatar
    Hello I am just using a 64gb sd card for my note 4 so I tried to transfer everything from my old card to this card and 1. Its not taking all the files I'm transferring over 2. Some of the files that did transfer over when I open the folder it's empty when there's supposed to be things in it 3. I decided to put the card in my phone anyway and when I take a picture it saves but later it shows that it's a corrupted picture, I put the storing location to memory card and it's saying it can't store pictures on the card I wasn't going thru this with my old card....
    12-06-2015 09:36 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! How did you transfer the files from old card to the new one? Using Windows Explorer?
    What brand is the new card, and where did you get it from? It could be defective or counterfeit. Run SD Insight to check if it's a genuine card. If it's genuine, then Unmount the card (in Settings>Storage), remove it, and insert it into your computer. Then run chkdsk to look for bad sectors. [GUIDE] Using chkdsk to fix a corrupted SD card
    12-07-2015 06:29 PM
  1. how to charge N5x
    By ezzzzz in forum Nexus 5X
    Last Post: 12-08-2015, 02:27 PM
  2. samsung galaxy grand prime unable to send pictures with text
    Last Post: 12-06-2015, 07:00 PM
  3. How do I delete or share photos from my text album?
    By AC Question in forum Samsung Galaxy S6 edge+
    Last Post: 12-06-2015, 10:01 AM
  4. Replies: 1
    Last Post: 12-06-2015, 09:33 AM
  5. Why rooting my J500F failed?
    Last Post: 12-06-2015, 09:22 AM
