1. AC Question's Avatar
    hi. i dropeed my galaxy s3 from bed to the ground. then the phone went completely blank. While i plug in the charger, the red led glows but no display. later when i press the power button the red led goes off but still no display and vibration. and while i unplug and plug it again, no charging, no led. then again i sud reinsert battery to make the led glow. Help me out please.
    12-06-2015 10:11 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! How long did you charge for? Keep it plugged in for at least 4-6 hours undisturbed, then try pressing and holding Power for at least 20-30 seconds. If nothing happens, it might be worth trying a new or different battery. But it sounds like it's more of an issue with internal hardware damage. It could be motherboard damage, but it might just be a damaged power button. I'd suggest bringing it to a repair shop.
    12-07-2015 06:22 PM
  1. I need to know how to fix whats going on with my note 4
    Last Post: 12-07-2015, 06:29 PM
  2. Why are some apps extremely slow on Tab 3?
    Last Post: 12-07-2015, 06:23 PM
  3. Replies: 2
    Last Post: 12-07-2015, 07:40 AM
  4. Replies: 2
    Last Post: 12-06-2015, 09:59 AM
  5. Why can't I open cmw recovery mode?
    Last Post: 12-06-2015, 09:54 AM
