1. AC Question's Avatar
    So about 2 months ago I got the S6 Edge from Verizon, and it is awesome except that my battery is awful. I get maybe 10 hours per charge with 2 or less hours of screen time. I have searched the internet, trying everything from clearing the cache partition to turning on advanced calling. I have even factory reset the phone. I have contacted Verizon twice, and they haven't helped. Anybody have a solution? My phone should not be loosing 1% every 30 minutes on standby, and I know the battery lasts up to 24 hours with 4 hours of screen on time for some people. Suggestions please?
    12-06-2015 05:07 PM
  2. belodion's Avatar
    Welcome.
    1) What do your battery usage stats say at the end of the day?
    2) Also, tap the graph to expand it: what is your signal and awakes history for the same period?
    Those two screenshots, posted here, will help us to diagnose any trouble.
    12-06-2015 05:42 PM
  3. Hock3y Monk3y29's Avatar
    I will upload them at the end of my battery tomorrow so they are accurate. Also, when I click on the graph, it does not expand. I can upload a screenshot of GSam battery monitor if that helps?
    12-06-2015 06:12 PM
  4. belodion's Avatar
    Welcome as a new member.
    Yes, there are some useful graphs in that.
    12-06-2015 06:25 PM
  5. Hock3y Monk3y29's Avatar
    12-07-2015 08:58 PM
  1. Verizon LG G3 - Video will not attached to message
    Last Post: 12-07-2015, 03:48 PM
  2. Adding a Chrome bookmark to home screen - Odd issue
    By The Lip in forum Android 6.0 Marshmallow
  3. Does anyone know anything about USB Audio?
    By CrashAlpha in forum Android Auto
    Last Post: 12-07-2015, 03:11 PM
  4. Disable the pin #
    By NEH Question in forum Ask a Question
    Last Post: 12-07-2015, 03:44 AM
  5. Replies: 1
    Last Post: 12-06-2015, 08:09 PM
