1. AC Question's Avatar
    My note 4 charges a bit slower than usual. Especially when it's up to 70% , it charge even slower. But when I remove the battery and put it back it shows that it has more than 90%.
    This happens to my phone like more than 2 times/week. I has to remove my battery and put it back to make it charge normally. I really need your help.
    Thank in advance
    12-07-2015 10:40 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! The battery sensor software might need recalibration. Try charging up overnight to 100%, using it normally until the phone shuts off from low battery, then charge back up again and repeat the cycle about 3 times. See if the battery reading is more accurate.
    12-07-2015 11:42 AM
  1. Replies: 26
    Last Post: 02-21-2017, 08:08 PM
  2. Can I use my old Samsung GS3 charger to charge the Nexus 6P?
    Last Post: 12-07-2015, 11:54 AM
  3. Not showing if someone is calling
    Last Post: 12-07-2015, 11:52 AM
  4. Why does my screen stay active while on the phone?
    Last Post: 12-07-2015, 11:44 AM
  5. Replies: 1
    Last Post: 12-07-2015, 10:41 AM
