1. AC Question's Avatar
    I got a Samsung Galaxy S4 not too long ago, and it dies extremely fast. Theres absolutely nothing wrong with it and I didnt even download any apps yet. No pictures are stored on it, and everything is fresh. But the thing is, if its fully charged it dies. When I take it off charge, I only have like 5 minutes to use it and then its dead. It drains too quickly. Even if its at like 60 percent, it will still die. The only way I can use it for more than 5 minutes is if its on charge while im using it. Help!! Thank you.
    12-08-2015 02:04 AM
  2. Javier P's Avatar
    Hi, welcome to the forums! You should try replacing the battery for a new one. It looks like a battery problem.
    12-08-2015 06:17 AM
  3. Stormdrunk's Avatar
    Welcome!
    Definitely sounds like a battery problem. I'd do another hard reset to see if that helps. If not, eBay or Amazon is probably your best bet for a new battery, can get them for around $10.
    Good luck!
    12-08-2015 06:44 AM
  1. Easiest way to switch phone and settings
    By reb0957 in forum Google Nexus 6
    Last Post: 12-09-2015, 07:18 AM
  2. Pictures slowly disappearing from Phone gallery.
    By Jonesphb in forum Samsung Galaxy S5
    Last Post: 12-08-2015, 07:02 PM
  3. Why has contact manager stopped working on my Lenovo S650?
    Last Post: 12-08-2015, 03:25 PM
  4. I can't download apps in my moblie phone, so tell me what is the reason?
    Last Post: 12-08-2015, 06:22 AM
  5. I can't swipe away icons but can swipe other things Help
    Last Post: 12-07-2015, 10:44 PM
