1. jared estrada's Avatar
    I rooted a phone (blu life one 4lte) and tried to flash a custom recovery. In my part I didn't know which recovery was good for my phone and so I did the closest to what I was running which was kk and so I rebooted it and got stuck on the loading screen. I can go into what it seem like stock Android recovery. It gives me the option to reset my phone but when I do it and pick reboot normally I get the same thing. The options are reboot system, apply update from ADB, wipe data, wipe cache, apply update from sdcard. I need help on getting it unstuck. Please help message me back on my email if you have any suggestions on what should I do
    12-08-2015 07:29 PM
  2. dpham00's Avatar
    Which custom recovery did you try to flash?
    12-10-2015 04:31 PM
  1. I would like to know which apps comes with the phone out of the box.
    By lefthookvillain in forum Samsung Galaxy S6 edge
    Last Post: 12-13-2015, 08:18 AM
  2. I have bought Xperia Z2 and I need some help
    By Goke in forum Sony Xperia Z2
    Last Post: 12-08-2015, 09:45 PM
  3. How can I fix some Samsung Note 4 heat problems?
    By AC Question in forum Samsung Galaxy Note 4
    Last Post: 12-08-2015, 07:22 PM
  4. Why won't my phone sync with my car?
    Last Post: 12-08-2015, 06:48 PM
  5. Replies: 0
    Last Post: 12-08-2015, 06:44 PM
