1. AC Question's Avatar
    Hello, since one week ago when the air view is on, all the featured apps, like, messages, gallery, contacts, the touchscreen won't work when i'm in one of this apps. When I turn the air view off, everything is workkng fine. I tried removing the battery, factory reset. Any ideas? Thank you
    12-09-2015 02:37 PM
  2. dpham00's Avatar
    If this feature is important to you then I would suggest that you contact the manufacturer for a warranty replacement
    12-09-2015 02:59 PM
  3. Fuzi26's Avatar
    If not? Use it like this? It wont get worse?
    12-09-2015 03:04 PM
  1. Replies: 2
    Last Post: 12-13-2015, 11:02 AM
  2. Replies: 1
    Last Post: 12-09-2015, 02:43 PM
  3. How do I hard reset a Galaxy S6 that has a broken screen?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 12-09-2015, 02:31 PM
  4. How do I hard reset a Galaxy S6 that has a broken screen?
  5. Replies: 1
    Last Post: 12-09-2015, 02:21 PM
