How do I set up the easiest way for a mobile hot-spot
A
AC Question
Well I've went over my usage on my data plan so I am trying to set up and keep connection until I shut it off and mobile hotshot I went through settings followed it used Bluetooth connection also and connected it the way it said but I need to know how do I know if I did it right and is there an easier way
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,533
4,668
113
Welcome to Android Central! I'm not entirely clear on this--you've maxed your phone's data plan, so you want to try using it as a hotspot? The data used from the hotspot comes from your mobile data allotment as well. so if you've maxed out your data for the month, you won't be able to tether (or you'll only be able to tether at very low speed, like 2G).
Dominic Haar
