1. AC Question's Avatar
    when i am at an rv resort in the country, my samsung adroid phones battery discharges much faster than when i am in an urban area. the phone service in the country is very bad with me only getting maybe one or two bars. is the battery usage due to roaming?
    12-12-2015 11:55 AM
  2. minion123's Avatar
    Signal is lower and phone uses more battery to get signal. usual thing I see in low signal places
    12-12-2015 12:12 PM
  3. AlphaTango414's Avatar
    If you are getting worse signal than you normally do then yes it's normal to see more battery drain. Your antenna is using more power to search and hold on to that signal.
    12-12-2015 12:59 PM
  4. dpham00's Avatar
    What they said. You can use an app like juice defender to turn off the mobile data, only enabling it occasionally,to improve battery life in this situation
    12-12-2015 01:03 PM
  1. consistent error when trying to purchase Samsung apps
    By ShaggyKids in forum Samsung Gear S2
    Last Post: 06-24-2016, 11:22 PM
  2. Replies: 1
    Last Post: 12-13-2015, 02:42 AM
  3. Replies: 1
    Last Post: 12-12-2015, 01:40 PM
  4. Replies: 1
    Last Post: 12-12-2015, 12:08 PM
  5. vocera not connected on android note 5
    Last Post: 12-12-2015, 12:06 PM
