1. AC Question's Avatar
    If I move too much it cuts off and if I try to cut it back on the slightest movement will cut it back off I need some help
    12-14-2015 02:30 AM
  2. Laura Knotek's Avatar
    Hi and welcome to AndroidCentral.
    I'm not familiar with that device. Does it have a removable battery? If so, you might want to take a business card, fold it in half and place it behind the battery door. It sounds like the battery door is loose, causing the battery to lose contact due to just a little bit of jarring motion. Please let us know if that helps.
    12-14-2015 02:38 AM
  3. the tall guy's Avatar
    Hi, if the battery is loose you should take the device to a repair store to have someone look into it.
    12-14-2015 02:39 AM
  1. How can i stop or delete shortcuts Web games?
    Last Post: 01-16-2016, 11:07 PM
  2. How to keep Spotify screen on
    Last Post: 12-14-2015, 02:32 PM
  3. Replies: 1
    Last Post: 12-14-2015, 02:45 AM
  4. I cannot turn on my Samsung Galaxy Note 10.1, 2014 edition
    Last Post: 12-14-2015, 02:40 AM
  5. " Unfortunately: Phone has stopped" message on receiving calls.
    By vasanth gopi in forum Android 5.0 Lollipop
    Last Post: 12-14-2015, 01:43 AM
