1. Aaron's Avatar
    I am using a moto g 3rd gen....the battery lasts fr just about 7 or 8 hrs without much use....30 percent battery in 5 hours without any use....top consumers r mobile standby 71%
    Android os 30%
    Google services 23%
    12-15-2015 12:19 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! How's your cell signal strength? High mobile standby usage is often due to poor signal.
    Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    12-15-2015 12:43 AM
  1. Battery Life?
    By crazyralph90 in forum LG V10
    Last Post: 12-21-2015, 12:53 PM
  2. How can i get lollipop off my moto x!?!?!
    Last Post: 12-15-2015, 02:48 AM
  3. Replies: 1
    Last Post: 12-15-2015, 12:45 AM
  4. Replies: 0
    Last Post: 12-14-2015, 11:26 PM
  5. Can I reset google play store version 5.9.12?
    Last Post: 12-14-2015, 10:47 PM
