1. unoahpwe's Avatar
    I have a verizon s5 brand new and I am experiencing battery drain and overheating problems. at school i'll have the brightness close to the lowest with battery saver on yet its overheating and dropping like crazy the picture i provided i just had 10 minutes of on screen time with almost lowest brightness and battery saver and dropped that quick
    Attached Thumbnails verizon S5 lollipop problems-screenshot_2015-12-15-12-16-39.jpg
    12-15-2015 04:31 PM
  2. ColbyJvonBrown's Avatar
    Seems to be your service. (I see the No Sim Card symbol in the Status Bar) You have 0 Bars. Maybe you should put it in Airplane Mode, cause WiFi will still work that way. If you keep it of Airplane Mode without a Sim Card, it can and will kill your phone battery rapidly, which could explain the overheating. But a rogue app can also be the cause of your battery drain and overheating. Also do you have a specific display setting like say 25%, 50%, etc.
    12-15-2015 04:36 PM
  3. unoahpwe's Avatar
    no i use the display usally around this level and also i dont have the phone activated i bought it to use it with straight talk
    Attached Thumbnails verizon S5 lollipop problems-screenshot_2015-12-15-14-24-02.jpg
    12-15-2015 04:40 PM
  4. AlphaTango414's Avatar
    Yes, very low signal or no signal will drain a battery pretty quick. Is wifi available at your school? If so, use it, and turn off mobile data.
    12-15-2015 04:41 PM
  5. unoahpwe's Avatar
    its not low signal I dont have the phone activated nor have mobile data on
    12-15-2015 04:42 PM
  6. unoahpwe's Avatar
    airplane mode is not helping at all
    12-15-2015 04:57 PM
  1. Blackberry Priv on Verizon
    By Blax ology in forum BlackBerry Priv
    Last Post: 12-17-2015, 03:34 PM
  2. I can't send Pics via Text on my S5 Active
    Last Post: 12-15-2015, 04:32 PM
  3. Replies: 1
    Last Post: 12-15-2015, 04:26 PM
  4. My Galaxy S5 won't load picture into messages??
    Last Post: 12-15-2015, 02:23 PM
  5. Replies: 1
    Last Post: 12-15-2015, 02:19 PM
