1. AC Question's Avatar
    I have recently noticed my battery draining much more quickly, when I checked battery usage in my settings it says my screen is using 48% of my battery
    12-18-2015 11:33 AM
  2. Finn Henderson's Avatar
    A screen will usually use a fair bit of power (depending on the type of screen). Some screens don't need to be very bright set to be visible, also contributing to low power usage.
    Your screen either just uses a lot more power than some in general; or you have it set to maximum brightness settings
    12-18-2015 11:35 AM
  1. Replies: 5
    Last Post: 02-03-2016, 06:27 AM
  2. problem when i try to save new contact in galaxy s4
    Last Post: 12-19-2015, 02:38 AM
  3. 360 Security has blocked my handy, What can i do?
    Last Post: 12-18-2015, 11:57 AM
  4. 4G has stopped working on my Microsoft phone. any ideas?
    Last Post: 12-18-2015, 11:37 AM
  5. why am i not able to open my account on viber?
    Last Post: 12-18-2015, 11:17 AM
