1. AC Question's Avatar
    Phone does not turn on
    12-19-2015 09:42 AM
  2. dpham00's Avatar
    What phone do you have?
    12-20-2015 10:07 AM
  3. darksngel119's Avatar
    The phone sounds like a Samsung from the blue light. I would try hard reseting it. Power button plus volume down for 10 seconds.
    If that doesn't work then it sounds like your screen went out. If less then a year old I would take it to your carrier for a warranty replacement.
    If more than a year old then I would try Ifixit.com for repair instructions or take to a repair shop
    12-20-2015 10:53 AM
  1. Replies: 4
    Last Post: 12-22-2015, 12:07 PM
  2. Replies: 1
    Last Post: 12-19-2015, 10:34 AM
  3. Issue with Alarm wakeup after phone restart and switch off and on
    By itscrazylife in forum Android App Inventor
    Last Post: 12-19-2015, 09:20 AM
  4. Replies: 1
    Last Post: 12-19-2015, 09:12 AM
  5. Replies: 0
    Last Post: 12-19-2015, 08:52 AM
