1. AC Question's Avatar
    What do I need to do to get S4 with verizon to work on android auto
    12-19-2015 04:56 PM
  2. hallux's Avatar
    Have you installed the Android Auto app?
    Install that, plug your phone into the head unit and you should be on your way. You might also consult the manual for your particular in-vehicle system to get the correct information about how to utilize the feature, without knowing what in-vehicle system you're working with people here can't look up the correct info to help you.
    There is also an Android Auto section here on Android Central, though you may need to register for a (free) account to be able to post in there.
    12-19-2015 05:07 PM
  1. Replies: 7
    Last Post: 11-30-2016, 07:40 PM
  2. Replies: 1
    Last Post: 12-20-2015, 09:16 AM
  3. What is wrong/happening? How do i get my photos back?
    By AC Question in forum Samsung Galaxy S6 edge+
    Last Post: 12-19-2015, 11:00 PM
  4. Replies: 1
    Last Post: 12-19-2015, 10:30 PM
  5. Will a mophie for the Galaxy S4 fit Galaxy S6?
    Last Post: 12-19-2015, 05:10 PM
