1. AC Question's Avatar
    wifi is recognised bydesk top but tablet will not connnect (used to)
    12-19-2015 09:01 PM
  2. srkmagnus's Avatar
    Try resetting the router by unplugging the power source for a minute or two then plug it back in. I'd also suggest forgetting the network then try adding it back by selecting it from the WiFi connection settings. Also make sure you input the correct password when connecting.
    AlphaTango414 likes this.
    12-19-2015 09:30 PM
  3. darksngel119's Avatar
    Also try doing hard reset on tablet. Which is power + volume down for 10 seconds. Don't worry won't erase any of your stuff.
    12-19-2015 11:23 PM
  1. Replies: 2
    Last Post: 12-19-2015, 11:31 PM
  2. Is it possible to name my device/Galaxy Nexus 4.2.2 Android?
    By AC Question in forum Google Nexus 4
    Last Post: 12-19-2015, 11:03 PM
  3. How do I increase the number of rings on my Galaxy S5?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 12-19-2015, 10:17 PM
  4. How do you take the back off to replace the battery?
    Last Post: 12-19-2015, 08:06 PM
  5. Verizon galaxy s4 school 1545 5.0.1 rooting
    By Wphall in forum Ask a Question
    Last Post: 12-19-2015, 07:37 PM
