1. AC Question's Avatar
    when I put my battery in my phone it turns on by itself and starts flashing the LG sign and doesn't fully turn on, it just keeps flashing LG...what can I do to make it turn on?
    12-21-2015 08:40 PM
  2. AlphaTango414's Avatar
    Have you had problems with the device before this? Did you do a battery pull because it was frozen/locked up?
    Boot into recover and wipe system cache. Still no luck, flash stock firmware via LG Flash Tool.
    12-21-2015 08:57 PM
  3. AlphaTango414's Avatar
    Download and install LG Drivers
    Download and install LG Flash Tool
    Download stock firmware.
    Place device in download mode. Power device off, while holding volume up, plug computer usb cable into your phone.
    Run the LG Flash tool .exe file
    Select “CDMA” as device type and "Diag” as phone mode.
    Use the KDZ file you previously downloaded.
    Use CSE flash option.
    Click start and choose your language in the pop up window.
    Hit ok and don't touch anything until it says 100%.
    12-21-2015 08:57 PM
  1. Why is every new thing is missing when I restart?
    By AC Question in forum Sony Xperia Series
    Last Post: 12-22-2015, 01:24 PM
  2. Replies: 2
    Last Post: 12-22-2015, 10:58 AM
  3. Replies: 1
    Last Post: 12-21-2015, 08:19 PM
  4. My native weather display disappeared, how do I get it back?
  5. Replies: 1
    Last Post: 12-21-2015, 08:00 PM
