1. Brittany Ann Amor's Avatar
    Maybe for about a week now, my phone's battery will decrease when I plug it in, or it won't charge as quickly as it used to.
    I'm using the same Fast Charging Adapter and everything, and the status bar even shows that it's "Fast Charging" when it's plugged in. But my phone will be at 20% when I start charging it, and it'll go down to 19% if I use it. This didn't use to be a problem. ): I tried downloading a Battery Doctor, but I just uninstalled it because I thought it was making it worse.
    I'll appreciate any help I can get! Thank you~ ♡
    12-22-2015 06:06 AM
  2. anon(632115)'s Avatar
    It depends what your usage is. If you use it while on charge it's a bit like trying to fill a bath without the plug in the drain. What happens if you allow it to charge, without any usage?
    12-22-2015 06:38 AM
  1. My Galaxy Ace s53801i is stuck on odin mode! How to reset it?
    By AC Question in forum Samsung Galaxy Ace
    Last Post: 12-22-2015, 07:03 AM
  2. my galaxy ace s53801i is stuck on odin mode! how to reset it?
    Last Post: 12-22-2015, 07:02 AM
  3. Samsung Galaxy S3 lte; GPS not working in stock ROM
    By AC Question in forum Samsung Galaxy S3 Rooting, ROMs, & Hacks
    Last Post: 12-22-2015, 07:01 AM
  4. Galaxy S4: Can't reinstall email?
    By AC Question in forum Samsung Galaxy S4
    Last Post: 12-22-2015, 05:17 AM
  5. Replies: 1
    Last Post: 12-22-2015, 03:05 AM
