1. karim Mahmoud1's Avatar
    I have a strange problem with my phone gt-s7582 cm12.1 . first of all, I have battery drain sometimes from 15% to 0% and sometimes from 30% to 0% and not only in cm12.1 but also on the stock rom but this not the problem actually this OK for me. the strange problem is that I can't charge my phone to 100% at first I could only charge to 94% then after 2 days I could charge to 75% only and now I can't charge more than 60%. I have bought 2 batteries and the problem even with the stock rom . something else that when I change the battery I get the same battery %. so if now the phone says that the battery is 40% and I changed the battery it will give me 40%. please anyone tell me how can I solve these problems.
    all the previous problems is the same with the stock ROM so the problem is not in cm12.1
    12-23-2015 03:25 PM
  2. AlphaTango414's Avatar
    Look up how to calibrate your battery for your device.
    12-23-2015 03:33 PM
  3. karim Mahmoud1's Avatar
    I did that many times and it does nothing.
    12-23-2015 03:36 PM
  1. Replies: 1
    Last Post: 12-24-2015, 06:37 PM
  2. Replies: 2
    Last Post: 12-23-2015, 09:43 PM
  3. Why will my HTC One not pair with my Fitbit Flex?
    By AC Question in forum HTC One Series
    Last Post: 12-23-2015, 03:39 PM
  4. Did an update put Android web view on the phone?
    Last Post: 12-23-2015, 02:34 PM
  5. Replies: 0
    Last Post: 12-23-2015, 01:33 PM
