1. AC Question's Avatar
    I just updated my S5 active. When i went to charge it 2 nights ago the battery went from around 2% to 51% in about 7 hours. So the whole day it was pretty much kept on a charger and never got above 20%. So last night I shut it off and charged it and it only charged to 92% in 8 hours and that was off. It has never charged this slow before, it literally just started happening. I haven't tried any different chargers but i know mines not damaged or anything. And the battery drains to fast. I turned it on at 92% and put spotify on (offline mode) and hopped in the shower. Got out maybe 15 minutes later and it was at 75%. So should i get a new charger and try that or is it the battery or the update?
    12-24-2015 12:34 PM
  2. 12MaNy's Avatar
    Sounds hardware related (bad battery), but I could be wrong. Go with the process of elimination my friend. Go into settings and see if anything is draining your battery unneededly. Then, inspect the charging port, then try a different charger. If that doesn't work, get another battery......etc.
    12-24-2015 12:56 PM
  1. Cant hear the volume i would like to know where is located
    Last Post: 12-24-2015, 12:30 PM
  2. why the sensor of my s4 fail ?
    Last Post: 12-24-2015, 12:25 PM
  3. Cant update to lollipop
    Last Post: 12-24-2015, 12:21 PM
  4. Replies: 1
    Last Post: 12-24-2015, 12:19 PM
