1. AC Question's Avatar
    I received a pop up notification with something along the lines that your battery will charge faster if you charge with apps turned off and asked if I wanted to do it. so I did. when it was on the screen it had a blue wave and 3 circles in the center first said charging with the percentage. middle one can't remember and the third said Trickle. it had pop up ads on the bottom. and it made it to where you had to slide the screen to the right to open it, similar to the iPhone. in the upper right corner that was a button to disable.. I hit the disable and now can't find it again. has anyone else seen this??
    12-25-2015 02:33 PM
  1. Replies: 2
    Last Post: 02-04-2016, 08:58 AM
  2. Notification Lights
    By bad1550 in forum Nexus 6P
    Last Post: 12-27-2015, 08:48 PM
  3. Does storage capacity affect the battery life?
    By AKFL3TCH3R in forum Moto X Pure Edition
    Last Post: 12-26-2015, 02:36 PM
  4. My Galaxy S5 was charging and never turned back on?
    By AC Question in forum Samsung Galaxy S5
    Last Post: 12-25-2015, 12:58 PM
  5. Didn't charge LG G4 when I got it.
    By xStef in forum LG G4
    Last Post: 12-25-2015, 08:50 AM
