1. Justin J3's Avatar
    So I bought a used s5 galaxy down on the "Amazon" and right away I noticed some funky battery issue. .
    It is a used phone.
    I charged the battery for a bit. Turned it on. Went through the startup process. And everything seemed to work fine.
    BUT, here's where things got weird. .
    After installing a couple basic apps and seeing it up to my home wifi, etc, it suddenly shut down even though the battery bar was at 100%
    So then I charged it for a couple hours, everything working swell, but after using for a hour or two I was shocked the battery was still at 100%!
    The battery bar always shows its full but after some usage it will eventually shut down and I have to charge again and right away it says it's at 100% (also when plugging in the charger or shows 99% charge even though it just died..)
    The phone seems to run just fine after charging but I can never see where my battery level is! It will just randomly shut down when the battery is depleted.
    What could be causing this? ???!
    Thanks^.^
    12-27-2015 06:20 PM
  1. Samsung Galaxy S5 bootloop/black screen problem. Please help!
    Last Post: 06-25-2016, 05:27 AM
  2. Replies: 2
    Last Post: 12-28-2015, 07:05 PM
  3. Replies: 2
    Last Post: 12-27-2015, 08:07 PM
  4. My LCD screen on my samsumg S5 is flashing
    Last Post: 12-27-2015, 06:17 PM
  5. How can I override Google Speech on locked Nextbook 7 Tablet?
    Last Post: 12-27-2015, 05:53 PM
