1. AC Question's Avatar
    and then when I used it this morning I started seeing the battery percentage ticking away right in front of me, about 1% every 10 seconds, when I put it into rest mode the battery stopped draining rediculously fast, I took a screenshot of the battery use, I also had no apps open I will post the picture if it's alright
    12-30-2015 09:21 AM
  2. STARGATE's Avatar
    I can only speculate here.
    Battery might be bad or too old. Software running crazy.
    Clear cache, turn the phone off for a minute or two, or take the battery out if the phone has a removable battery. Than turn it on, charge it and see what it does.
    Last resort, save your data and than do a factory reset.
    If you just got the phone, return/exchange it.
    Let us know what happens.
    12-30-2015 09:38 AM
  1. Replies: 3
    Last Post: 01-14-2016, 02:13 AM
  2. Replies: 2
    Last Post: 12-30-2015, 11:40 AM
  3. Replies: 1
    Last Post: 12-30-2015, 09:40 AM
  4. Where's the Delete (my post) Button?
    By Oldwisewiz in forum Site Feedback & Help
    Last Post: 12-30-2015, 09:20 AM
  5. Replies: 1
    Last Post: 12-30-2015, 09:15 AM
