1. AC Question's Avatar
    It is a real pain when trying to text or open an app. Really have to tap hard or hold on the item. Using swype is nearly impossible some times. How can I adjust screen sensitivity?
    12-30-2015 04:25 PM
  2. sydneycooper1979's Avatar
    Hello! Try clearing the cache partition and if this doesn't work, try a factory reset.
    12-30-2015 05:35 PM
  3. Baddddad's Avatar
    This solved my very similar issue
    -in dialer type *#2663#
    -TSP firmware update (general)
    You should see "PASS"
    01-12-2016 09:38 AM
  1. Cant Get Into My Phone
    Last Post: 12-30-2015, 06:18 PM
  2. Why won't my phone download apps?
    Last Post: 12-30-2015, 04:22 PM
  3. Replies: 0
    Last Post: 12-30-2015, 04:21 PM
  4. How do I recover my contacts from a broken android LG3 ?
    Last Post: 12-30-2015, 04:20 PM
  5. How to change soft buttons on l lg g flex
    By bloodeyed77 in forum Ask a Question
    Last Post: 12-30-2015, 03:57 PM
