1. AC Question's Avatar
    My phone was working perfectly, until this message popped up, and I can't enter the password to get into it AT ALL, NOW!! I already turned it off and on, and took out the battery multiple times!!! NOTHING WORKS!!!!! PLEASE HELP!!!!!!
    12-30-2015 06:42 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! This seems to happen more often with the lower-end LG phones than with any other brand. One possible solution is to get an OTG adapter and a cheap USB keyboard, and use the keyboard to enter the password. Once you've unlocked the screen, I'd install an alternate keyboard (like Google Keyboard or Swiftkey), and make that default.
    12-31-2015 04:49 AM
  1. Replies: 2
    Last Post: 02-03-2016, 12:57 AM
  2. Replies: 1
    Last Post: 12-31-2015, 04:56 AM
  3. Why won't my Android tablet connect to wifi at any location?
    By Trinadh in forum Misc. Android Tablets
    Last Post: 12-30-2015, 08:47 PM
  4. Note 4 LCD Replacement- Touchscreen Not Working?
    Last Post: 12-30-2015, 06:36 PM
