1. LukeMannnnnn's Avatar
    I was just curious if the Samsung Galaxy VR will work with a GS6 if I leave the Lifeproof Case I have on on the phone? Will it fit into the Galaxy VR? I want to purchase the VR but don't want to have to remove my Lifeproof Case every time I want to use it.
    If it does work will leaving the case on detract from using the VR in any way?
    Also as a final question for all of those who have the Galaxy VR is it even worth buying? Do you enjoy using it? Or should I wait and purchase a non-smartphone VR system?
    Thanks for your help.
    01-01-2016 08:37 PM
  2. srkmagnus's Avatar
    I can't say for certain, but from what I understand, the phone fits snug inside the VR casing. So by that, I would say no, it would not fit within the VR with the Life Proof case.
    For the second question, hopefully someone with experience can chime in for you.
    Laura Knotek and LukeMannnnnn like this.
    01-01-2016 10:15 PM
  1. Did Samsung abandon the Gear S?
    By Jasp615 in forum Samsung Gear S
    Last Post: 04-16-2016, 03:06 AM
  2. Replies: 2
    Last Post: 03-14-2016, 10:09 AM
  3. Will the NFC chip in the Gear2 work with Android Pay?
    Last Post: 01-01-2016, 08:23 PM
  4. Wind Samsung S4 SGH-M919V. What custom rom are out there?
    By Was33n in forum Samsung Galaxy S4
    Last Post: 01-01-2016, 07:41 PM
  5. Replies: 0
    Last Post: 01-01-2016, 07:32 PM
