1. Naturalgal 99's Avatar
    Its reboots at the LG onscreen logo. Shuts down at thatpoint the n powers back up over and over. I have done the estart to factory reset.went right back to same bootloop.any suggestions?
    01-03-2016 11:03 AM
  2. srkmagnus's Avatar
    Unfortunately I don't think there is. I was going to suggest a reset, but since you already did and it's still rebooting the problem may be deeper. Can you replace the battery? Sometimes that seems to be the problem and a new battery will fix it. It's probably the cheaper fix before sending it to LG (if that's an option) for repair or replacement.
    01-03-2016 11:16 AM
  1. Does knox Warranty void: 0x0 mean I voided my warranty?
    By AC Question in forum Samsung SAFE and KNOX
    Last Post: 01-03-2016, 11:40 AM
  2. Is this normal when I look at my storage capacity in my Note 4?
    By Cassie_RVT in forum Samsung Galaxy Note 4
    Last Post: 01-03-2016, 11:01 AM
  3. Replies: 0
    Last Post: 01-03-2016, 10:52 AM
  4. Replies: 1
    Last Post: 01-03-2016, 10:48 AM
  5. How do I access my photos in private?
    Last Post: 01-03-2016, 10:43 AM
