1. MissDeeDot's Avatar
    So I used to have just the swipe to unlock my phone then I switched to the finger print. It's been quite annoying so I went to switch back but it tells me that administration or something has stopped it or something rather I have a picture. Can someone please tell me how to fix this issue? Thanks!
    01-03-2016 07:48 PM
  2. belodion's Avatar
    Welcome.
    Go to Device Administrators in Settings, Security, and uncheck the appropriate box there.
    01-03-2016 10:36 PM
  3. MissDeeDot's Avatar
    I've tried that and the only thing was the clean master or whatever. And that didn't change it
    01-04-2016 03:22 AM
  4. MissDeeDot's Avatar
    Figured it out! Had to clear cresidentials. Whatever that is. Thanks for the help!
    01-04-2016 03:25 AM
  5. AlphaTango414's Avatar
    Get rid of clean masters. Horrible app for any Android device.
    01-04-2016 04:39 AM
  6. Kentballan01's Avatar
    Great site, new member here. I just had this problem as well. Thank you for the help!
    01-24-2016 04:52 AM
  1. Replies: 1
    Last Post: 01-04-2016, 03:27 PM
  2. My Samsung Galaxy E5 has frozen how do I unfreeze it
    Last Post: 01-03-2016, 10:39 PM
  3. I crackedmy screen on s5 active. How do I fix it?.
    By Cargill45 in forum Ask a Question
    Last Post: 01-03-2016, 08:01 PM
  4. How to fix Samsung Galaxy s3 water damage?
    By xMegatron81 in forum Samsung Galaxy S3
    Last Post: 01-03-2016, 07:29 PM
