1. AC Question's Avatar
    My S4 has been working fine for over a year. First, it had a problem of not reading my sim card but I ignored it since I put my sim on an another phone instead. I only use three chargers for my phone: the one that was with the package, my samsuny galaxy note charger and my telpad charger which also has the same volts and amps as my charger. Now all of a sudden, my samsung s4 had problems with charging. It started not to recognize some chargers so used my telpad charger and table and it went well but yesterday, the charging problem came back again. I'm afraid that this is a big issue. I went into a repair shop and said it was a problem in the port. But I'm also afraid that it's a bigger issue.
    P.S I admit that I charge it overnight or use it while charging sometimes. ((
    01-04-2016 08:21 AM
  2. dpham00's Avatar
    It is hard to tell what exactly the problem could be just from a rough description. But chances are, it is the charging port
    01-04-2016 09:56 AM
  1. What have you done to make the 6p easier to hold?
    By dirtyjudo in forum Nexus 6P
    Last Post: 02-03-2016, 09:39 AM
  2. Problems using american AT&T phone in the UK? have rooted but...
    By caspergotchi in forum Samsung Galaxy S6 edge Rooting, ROMs, & Hacks
    Last Post: 01-05-2016, 03:57 PM
  3. Replies: 0
    Last Post: 01-04-2016, 08:09 AM
  4. Why does my Android tv mx box keep rebooting?
    Last Post: 01-04-2016, 08:01 AM
  5. how can I unlock my 360 Security on my Smart phone.
    Last Post: 01-04-2016, 08:00 AM
