A
AC Question
Hi there, I have a galaxy s6 edge, and I like using miracast. I use the belkin miracast and it works ok, but every now and then I have to restart my phone and reconnect because the audio becomes messed up when connecting. Restarting the actual miracast device does not work, only restarting the phone itself fixes the issue,
So, at first I thought this was just an issue with the miracast device, but I got a fire tv stick from amazon and it has a miracast option. So, I wanted to try it out and when I tried to play a video file the audio was messed up and had to restart the phone like I did on the belkin device, so this makes me believe it is a problem with the phone.
Has anyone else experienced this audio issue with miracast? And, if so, is there a better fix then restarting the phone and reconnecting as this can get annoying at times.
