1. Scarecrow237's Avatar
    After discovering that the phone had died overnight I plugged it into the charger and waited for it to charge, I gave it about 6 hours to fully charge.
    After unplugging from the charger and trying to power up it will only power up to the point where you can see the Samsung white text on a black background and will not power up any further.
    I cannot power down. pressing the power button for a short press does nothing. Pressing and holding the power button in for ten seconds will cause the phone to go dark, vibrate once and then power back up to the Samsung title screen. Holding the power button for longer than ten seconds it will vibrate more than once and return to the Samsung screen.
    Pressing and holding the power button + the volume up button does the same thing pressing and holding the power button for ten seconds or more does.
    Since I cannot power the phone off, I cannot remove the battery.
    The place where purchased says they don't do repairs, but they are more than willing to sell me a new phone, which I don't want.
    How do I power off the phone, or otherwise make it work?
    01-05-2016 09:27 AM
  2. anon(632115)'s Avatar
    You can remove the battery without powering down. In fact, a battery pull can remedy a number of problems
    01-05-2016 10:21 AM
  1. Samsung Galaxy S7 Rumors
    By Nader Salem in forum Samsung Galaxy S7
    Last Post: 02-11-2016, 04:22 PM
  2. Replies: 2
    Last Post: 01-06-2016, 06:27 PM
  3. How does Chromecast Work?
    By Pesos_15 in forum General Help and How To
    Last Post: 01-05-2016, 04:29 PM
  4. How do I turn off chromecast?
    Last Post: 01-05-2016, 11:50 AM
  5. Samsung S2 mobile,
    Last Post: 01-05-2016, 09:19 AM
