1. AC Question's Avatar
    Pretty much when i plug my phone into a wall via a fast charge adapter my phone will charge from 0-100% within the hour. However when i do not use the fast charge plug and use a usb port on a computer for example it says it will take 3 hours 27 mins to charge and my phone is on 45%. Is this a common issue? and is there any possible way to make it quicker?
    Thank You
    01-06-2016 07:16 AM
  2. the tall guy's Avatar
    Hi, it isn't really a 'common issue' it's more fact - using the fast charger charges the phone fast, not using it doesn't charge it fast. Also. charging the device from a computer usb port will charge slower than any wall adapter as it's using less voltage to charge the device.
    01-07-2016 03:58 AM
  3. Feldon's Avatar
    You could upgrade your computer to a new motherboard with power-boosted USB ports. An expensive option to be sure.
    the tall guy likes this.
    01-07-2016 04:59 AM
  1. Samsung tab 3 won't turn onW
    Last Post: 01-07-2016, 03:24 AM
  2. Where does it show my new Samsung battery is charging
    Last Post: 01-07-2016, 03:17 AM
  3. samsung galaxy s5 cannot connect to a media device
    Last Post: 01-07-2016, 03:06 AM
  4. Why can I not transfer video files from my S6 to PC
    Last Post: 01-06-2016, 07:01 AM
  5. Galaxy 6 Edge contacts stopped syncing
    Last Post: 01-06-2016, 05:35 AM
