1. AC Question's Avatar
    My lg l65 flash light doesn't work after was fixed screen. Where is problem?
    01-06-2016 07:31 AM
  2. the tall guy's Avatar
    Hi, does the flash work when you take a picture, have you tried downloading a different flash light app from the play store?
    when you say the screen was fixed, did you fix it or was it done professionally - if you got it done professionally then take the phone back to them and see what they say.
    01-07-2016 04:08 AM
  1. Heating problem
    By Mert Ener in forum Samsung Galaxy Note 5
    Last Post: 08-16-2016, 07:42 PM
  2. Nexus 6P viewing angles problem?
    Last Post: 01-07-2016, 06:22 AM
  3. gear s problems...need help!!
    By Dan Horner in forum Samsung Gear S
  4. Can I get some help with flashing a rom?
    By AC Question in forum Samsung Galaxy Note Pro 12.2
    Last Post: 01-06-2016, 12:40 AM
  5. Replies: 0
    Last Post: 01-05-2016, 06:00 PM
