1. AC Question's Avatar
    My Samsung S6 battery is dead and no charger seems to work at the moment. One that was working, was actually draining my battery last night instead of charging it, by morning it was dead completely.
    When I did get some "life" from it the normal red light at the top came on and the battery icon on the screen came up but something that is new, is a green slow flashing light on the screen at the bottom. Does anyone know what this means? I'm currently charging it, but it is flashing this green light and charging super slow.
    It's not water damaged, and hasn't been dropped. I've only had this phone since June or July...
    Help!
    01-07-2016 08:35 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. You can try to reboot into recovery. Press Home, Volume up and power all at the same time. When the phone vibrates, release the power button. You should then see the android recovery screen and you can release the other two buttons.
    If you can't see anything, this may be a hardware issue. I would then contact Samsung before proceeding.
    01-07-2016 09:26 AM
  3. Hugo Candrahugo candra's Avatar
    Ohh its an indicator that the signal from the usb port is coming in my mother has a grand duo its the same light
    01-07-2016 10:08 AM
  1. Replies: 1
    Last Post: 01-08-2016, 09:18 AM
  2. Why is it so difficult to transfer music to my SD card?
    Last Post: 01-07-2016, 09:28 AM
  3. Replies: 1
    Last Post: 01-07-2016, 08:45 AM
  4. Replies: 1
    Last Post: 01-07-2016, 08:37 AM
  5. Note 5 and Gear VR Owners - What case do you use?
    Last Post: 01-07-2016, 08:33 AM
