1. AC Question's Avatar
    I have had a galaxy S4 for the past year and a half, The battery started becoming bad by getting drained quickly and turning off at 30%, When I opened the phone to see the battery it was getting bigger so I replaced it, Even after that I still have the same problem, The battery drains super fast from 100% to 70% and turns off at 30%, Even if I charge the phone to 100% and have it off, It drains while it is off!!!! I even tried formatting the phone and it still didn't work, Any fix would be very appreciable.
    01-09-2016 11:30 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Where did you get the replacement battery? Batteries can be defective or just plain poor quality, especially if you get them from some random seller on eBay.
    Some battery stats would be helpful. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    01-09-2016 05:56 PM
  1. Frickin' smartshare battery sucker
    By sswitzer in forum LG G4
    Last Post: 01-24-2016, 12:53 AM
  2. Samsung Galaxy S4 charging slowly
    By sted29 in forum Ask a Question
    Last Post: 01-12-2016, 05:39 AM
  3. How do I download my Galaxy S6 pictures to my HP computer?
    Last Post: 01-09-2016, 05:59 PM
  4. Samsung galaxy s3 memory card
    Last Post: 01-09-2016, 11:42 AM
  5. Replies: 0
    Last Post: 01-09-2016, 10:21 AM
