1. AC Question's Avatar
    I am using 'Simpler' as my contacts app, so I have no use of the contacts app automatically installed on my phone (I9505 running OctOS). However, when I disable the built in contacts app (I would uninstall it, but can't find it listed in my system app remover), I find that I can't actually create any new contacts through 'Simpler', therefore I have to keep the built in contacts app which, although is hidden from the app drawer through nova launcher, is still annoying. Any way I can disable/uninstall the built in contacts app and be able to add new contacts?
    01-09-2016 01:16 PM
  2. dpham00's Avatar
    I would contact the app developer to see if it is possible
    01-09-2016 05:38 PM
  1. Andriod phone gmail app won't sync with win10 email app.
    Last Post: 01-14-2016, 08:39 PM
  2. Delayed / Laggy Wake up with knock on...
    By KillerQ in forum LG V10
    Last Post: 01-13-2016, 02:38 PM
  3. Replies: 1
    Last Post: 01-09-2016, 05:44 PM
  4. Replies: 0
    Last Post: 01-09-2016, 01:13 PM
  5. Hiding notifcations from lock screen help
    Last Post: 01-09-2016, 01:10 PM
