Nexus 6P screen problem?
U
Unregistered
Hello everyone!
I saw lots of posts on the internet about the nexus 6P having dome sort of tint either pink or yellow. I do not know if mine does that. I mean looking at it straight it looks ok. But my problem is that at the slightest tilt of the phone the color change a bit to something a little greenish/bluish. Also at big angles the screen has a rainbow effect that i didn't notice on a s6 edge, for example.
I do not know if this is normal. It is a bit annoying because having the google keyboard which is a greyish color when i tilt it a bit it gets a little greenish. Is that normal? What should I do? I checked the manufacturing date and it is in Octomber.
The model is a 32GB Graphite.
Best regards!
