1. AC Question's Avatar
    1. Invalid Battery Shutdown. Phone keeps shutting off after displaying this message. I tried doing a hard reset, it didn't fix the problem. Bought a new battery, and THAT didn't fix the problem either. Cleared the cache data, but it still has the same problem. The battery is fully charged and will stay on for about a minute or two before shutdown occurs. Also, when the phone is on, the battery does appear to take a charge and it doesn't seem to be draining at an unusually fast rate.
    2. The front facing camera used to work fine. Now I can't access it.
    The phone has not experienced any catastrophic drops, nor has it been exposed to any moisture damage. These two issues just kind of happened out of the blue, and I have no idea why or how to fix them.
    01-11-2016 05:04 PM
  2. dpham00's Avatar
    I would contact the manufacturer for a warranty replacement
    01-11-2016 05:35 PM
  3. Qwn's Avatar
    I get the same problem on the same phone
    01-16-2016 09:17 PM
  1. What causes phones to root improperly or brick?
    Last Post: 01-11-2016, 06:38 PM
  2. Replies: 1
    Last Post: 01-11-2016, 05:40 PM
  3. Why can't I get my Irulu tablet to reset?
    Last Post: 01-11-2016, 05:38 PM
  4. help with chromecast
    By A_PAVONE726 in forum Ask a Question
    Last Post: 01-11-2016, 05:37 PM
  5. How do you screen shot on Galaxy S6
    Last Post: 01-11-2016, 04:36 PM
