1. beckybluecat's Avatar
    OK - I have a galaxy s3 mini which has started to switch itself off and drain the entire battery if I try using an app with 3g. its fine when using wifi.
    the same thing happened to my galaxy ace phone so I bought a new phone.
    im guessing I will have to do the same again unless anyone can offer some advice about the problem
    thank you
    01-12-2016 07:27 AM
  2. sydneycooper1979's Avatar
    Hello! You should probably take this to your carrier. I wonder if it could be the SIM card?
    anon(632115) likes this.
    01-12-2016 07:31 AM
  3. beckybluecat's Avatar
    thank you for your reply. Someone else suggested this so have ordered a new sim
    thanks again
    01-14-2016 07:45 AM
  1. Note 5 coming to the UK when?
    By George Jenkinson in forum Samsung Galaxy Note 5
    Last Post: 01-13-2016, 12:30 PM
  2. Watch dumped 80% of its charge in an hour
    Last Post: 01-12-2016, 10:20 AM
  3. Metro PCS / Cricket work in Canada?
    By psychoticprodigy in forum Ask a Question
    Last Post: 01-12-2016, 07:37 AM
  4. Replies: 1
    Last Post: 01-12-2016, 07:34 AM
  5. Replies: 2
    Last Post: 01-12-2016, 07:20 AM
