1. AC Question's Avatar
    Hey guys!
    I neead some pieces of advice really fast!
    My nexus 6P seems to have really really bad viewing angles..basically even if i move it a little while i am typing, the keyboard color gets bluish.
    Please watch this video (also please forgive the backround noise). This is my 6P. I know that the video is not of a very high quality (it was taken with my ipad 2) but you can still see the problem when i use the keyboard. It can also be seen when i try to reach the notification bar.
    Here is the video:
    http ://youtu.be/164m5oQu9yQ
    (Please remove the gaps)
    Is yours doing the same? Is it normal? Should I ask for a replacement? I am really curious if your 6P is doing the the same.
    Best regards!
    01-13-2016 02:04 PM
  2. belodion's Avatar
    Did you post about this before?
    Contact the manufacturer's customer support for advice if you are worried about your device.
    01-13-2016 03:23 PM
  1. Is there a way to remove the clock from the lock screen in Marshmallow?
    By AC Question in forum Android 6.0 Marshmallow
    Last Post: 01-20-2016, 06:33 AM
  2. Can I get some help for the Nextbook 8?
    By johnny9163 in forum General Help and How To
    Last Post: 01-19-2016, 05:34 PM
  3. How can you get rid of automatic wallpaper changer?
    Last Post: 01-13-2016, 02:43 PM
  4. Replies: 0
    Last Post: 01-13-2016, 01:03 PM
  5. G3 camera problem
    By utkarshc in forum LG G3
    Last Post: 01-13-2016, 12:04 PM
