1. Supriya45's Avatar
    Its been only 15 days since i bought my new samsung galaxy a5. Updated it to lollipop. I keep brightness usually minimum.But its battery still lasts only 4-5 hours even in power saving mode. ..Plzzzzzz help me i really need your help.
    01-15-2016 09:09 AM
  2. belodion's Avatar
    Welcome.
    What do your battery usage stats say after such a discharge?
    Also, a Cache Partition wipe after a system upgrade is a good idea.
    01-15-2016 11:14 AM
  3. Rukbat's Avatar
    4-5 hours on screen on time with full brightness is actually very good. 2-3 hours of screen on time with moderate brightness is normal.
    belodion and Laura Knotek like this.
    01-15-2016 12:15 PM
  4. belodion's Avatar
    ^ That's true. I was assuming the OP meant usage rather than SOT. If it's the latter, there's hardly a problem.
    01-15-2016 03:31 PM
  5. Supriya45's Avatar
    I tried this cache partition wipe thing but situation is still same.
    01-16-2016 06:47 AM
  6. Supriya45's Avatar
    I just use whatsapp , browsing,little bit fb . Play clash of clans hardly for 10 minutes in a day. Doesn't matter whether i use it less or more it still lasts for 5 hours.
    01-16-2016 09:58 PM
  7. Supriya45's Avatar
    01-16-2016 11:36 PM
  1. how to get grid view menu in solo launcher
    Last Post: 01-20-2016, 02:03 AM
  2. Samsung Galaxy S6 Edge - Steady Blue LED and Black Screen, unresponsive?
    By AC Question in forum Samsung Galaxy S6 edge
    Last Post: 01-15-2016, 11:47 AM
  3. Replies: 1
    Last Post: 01-15-2016, 11:43 AM
  4. Replies: 4
    Last Post: 01-15-2016, 11:25 AM
  5. Problems with widgets using Google Now Launcher, any ideas why?
    By rong21 in forum Samsung Galaxy S6 active
    Last Post: 01-15-2016, 08:30 AM
