1. dima manuel's Avatar
    using neighbors wifi how to boost weak signal any suggestions thanks
    01-19-2016 07:36 AM
  2. Tech-Newb's Avatar
    You're a naughty person if you steal neighbour's wifi. I dont think there is a way to boost wifi signal. Maybe a repeater can work.
    Or you can put 1 device that can share its network connection to the strongest point of the signal that you can reach so you can connect to that device instead.
    Posted with ❤Love❤
    01-19-2016 08:04 AM
  3. virtualtechie18's Avatar
    I don't know why you still need to boost it. It is just like, you were just depending on them yet you still want to boost yours. Lol.
    01-19-2016 08:07 AM
  4. pkcable's Avatar
    There's nothing you can do.
    Laura Knotek likes this.
    01-19-2016 08:21 AM
  5. Almeuit's Avatar
    Pretty much this.
    anon(632115) and pkcable like this.
    01-19-2016 09:05 AM
  1. connect to office wifi from home
    By dima manuel in forum Android 4.4 KitKat
    Last Post: 04-20-2016, 02:14 PM
  2. Replies: 13
    Last Post: 01-24-2016, 08:22 AM
  3. Replies: 6
    Last Post: 01-20-2016, 05:05 AM
  4. We wanted to use CardSpring but having trouble contacting them.
    By infymax_souvik in forum Android Apps
    Last Post: 01-19-2016, 07:27 AM
  5. Why can't I get my phone back to the way it was before?
    Last Post: 01-19-2016, 06:42 AM
