1. sabhi's Avatar
    When I inserted my sd card into my device starts freezing when I out it works properly
    01-28-2016 11:00 AM
  2. Sathu777's Avatar
    One of the files are corrupt or can't be read by the phone.try formatting every thing. Into fat 32 and delete any unnecessary files with other extensions.
    As a last resort format the SD card.
    If this doesn't work there is a problem with the SD so you should swap it out
    01-28-2016 11:15 AM
  3. Rukbat's Avatar
    Before you format anything, plug the card into a Windows PC and read Using chkdsk to fix a corrupted SD card.
    At absolute worst, use PhotoRec to recover everything on the SD card (except any apps you may have moved to it - which can be done, but is a bad idea) before formatting the card. Be prepared to wait a few days for PhotoRec to recover everything. It's thorough (it'll recover anything that can be recovered, but it takes time). You'll also lose file names (but not types - you'll get files like file0001.jpg or file002.mp4). Instructions are at PhotoRec Step By Step.
    01-28-2016 12:42 PM
  1. How do I downgrade Android 6.0 or change the emojis on Android 6.0??
    By AC Question in forum Android 6.0 Marshmallow
    Last Post: 05-26-2016, 02:00 PM
  2. Replies: 3
    Last Post: 01-28-2016, 06:55 PM
  3. Replies: 1
    Last Post: 01-28-2016, 12:45 PM
  4. Replies: 2
    Last Post: 01-28-2016, 12:34 PM
  5. Why don't my radio apps or Pandora load now?
    Last Post: 01-28-2016, 12:23 PM
