1. AC Question's Avatar
    have a rooted xolo 3000q i am trying to make partition for external storage for app. i used mini tool partition to make partitions on my 32 gb sd card. made 2 1 for media 28gb n remaining for apps which is around 2 gb n i make it as primary n use ext2. i installed kingo root to rooot my device n link2sd for moving the apps but when i open link2app i get a screen where it says select the file systum of ur SD cards second partision i choose ext2 i get a mount script error. mount script cannot be created. mount. no such device.
    dont know where i am going worn can some 1 help
    02-01-2016 04:02 AM
  1. How do I create a large group for texting?
    Last Post: 02-14-2016, 02:16 PM
  2. Why can't I reset my Samsung Galaxy Tab 3?
    By AC Question in forum Samsung Galaxy Tab 3
    Last Post: 02-01-2016, 12:49 PM
  3. No Command on pressing Reboot in recovery mode?
    Last Post: 02-01-2016, 02:32 AM
  4. Replies: 1
    Last Post: 01-31-2016, 08:45 PM
  5. cannot open or play games on boost mobile lg volt
    Last Post: 01-31-2016, 08:37 PM
