1. HaimeB's Avatar
    I have had my Samsung Galaxy S4 for a little over two years now. The battery isn't the best anymore, so I'm looking into a replacement. What is the best brand to look for? I've seen Zerolemon, Anker, and Stalion as popular ones; however, I don't just want to buy cheap and end up with a defective battery that may ruin my phone. What's the most reliable? Also, I'm not looking for extended batteries. I'd like to keep my phone the same size.
    02-02-2016 11:38 PM
  2. bs32315's Avatar
    I have used zerolemon and anker. Zero is good. Im using anker right now in my galaxy s3 and it is working great. If your worried about hurting the phone just but the stock battery from Samsung
    02-03-2016 12:27 AM
  3. PhiPsi32's Avatar
    Search the part number on Amazon. You will find a few options for OEM batteries. I've tried a number of after market batteries in my S4 & S5. None seem to do as well as the OEM model.
    02-03-2016 12:32 AM
  4. Tech-Newb's Avatar
    OEM is the best
    Posted with ❤Love❤
    02-03-2016 06:08 AM
  1. Replacing my Note 4 with a Nexus 6
    By Ravynmagi in forum Google Nexus 6
    Last Post: 02-11-2016, 11:05 PM
  2. Replies: 9
    Last Post: 02-03-2016, 05:42 PM
  3. Replies: 1
    Last Post: 02-03-2016, 01:01 PM
  4. Replies: 2
    Last Post: 02-02-2016, 10:42 PM
  5. Replies: 0
    Last Post: 02-02-2016, 05:14 PM
