1. AC Question's Avatar
    samsung s3 mobile heng problem solution
    02-04-2016 03:23 AM
  2. AlphaTango414's Avatar
    First thing first, boot into recovery and wipe system cache. This will not wipe any user data. Reboot and see if it boots all the way up. .
    If it still doesn't, here comes the sorta sour part. Boot back into recovery mode and do a factory reset. This will wipe all user data . You will have to set the device back up like it was new. Some things will automatically restore that's backed up with your Google account.
    If for some reason that still doesn't work, you're gonna have to flash stock firmware to the device. Use this guide for using Odin Software to reflash your device.
    02-04-2016 03:46 AM
  1. Replies: 7
    Last Post: 02-08-2016, 04:55 PM
  2. How to remove remote from Samsung note 4
    Last Post: 02-04-2016, 06:38 PM
  3. Replies: 1
    Last Post: 02-04-2016, 06:41 AM
  4. Samsung Galaxy S3 mini will not switch on
    Last Post: 02-04-2016, 04:51 AM
