1. Aviodwarf's Avatar
    Recently my droid maxx is slow and the battery drains incredibly fast, especially when data is turned on. I've already done a full factory reset, no help
    02-06-2016 08:23 AM
  2. Tech-Newb's Avatar
    Take a screenshot of your battry graph and the signal strength. You might have bad signal reception. Thats why your phone drains a lot battery and throttle.
    Posted with ❤Love❤
    02-06-2016 09:13 AM
  1. Notification LED issue (?)
    By EvilKittyCupcake in forum HTC One M9
    Last Post: 02-10-2016, 09:43 PM
  2. How do I fix battery drain caused by Google Services?
    By hempsader in forum Ask a Question
    Last Post: 02-06-2016, 09:18 AM
  3. talkback issue
    By lynn02 in forum Moto X (2014)
    Last Post: 02-06-2016, 07:20 AM
  4. can i disable battery charging trickle
    Last Post: 02-06-2016, 06:08 AM
  5. Samasung galaxy will not charge- says battery disconnected
    Last Post: 02-06-2016, 05:46 AM
