1. AC Question's Avatar
    My phone is behaving strangely from three days. I leave it to charge but it doesn't. instead it drains out.
    02-07-2016 01:02 AM
  2. Sathu777's Avatar
    Try using the adaptor that came with your phone.Some adaptors are rated for lower amp output as it would damage the device.
    unplug the original or other adaptor and you can see their amps.
    If you are not using a third party adaptor.Try turning off all the extras.such as gps, sync and use wifi over 4g/3g.
    The biggest factor is usually brightness so try and keep that low.If you have low reception your phone will continually search for better service.If you live or spend a lot of time in such an area it would be advised thaat you turn on airplane mode.
    If it is a massive problem until you can get the device repaired you should power it down.
    Good luck reply here if this problem persists and be sure to include details.Such as recent battery graphs.
    02-07-2016 12:43 PM
  1. Screen stutter when turning off screen
    By Zach91 in forum Samsung Galaxy S6
    Last Post: 02-09-2016, 10:46 PM
  2. What happened with the apps in my SD?
    By mrjulescesar in forum Android Apps
    Last Post: 02-08-2016, 05:35 AM
  3. No option for battery saver
    By k72 in forum Android 5.0 Lollipop
    Last Post: 02-07-2016, 09:31 AM
  4. Want charge with USB
    Last Post: 02-07-2016, 01:02 AM
  5. Can I cast video to my 2016 Toyota radio
    Last Post: 02-06-2016, 11:01 PM
