1. AC Question's Avatar
    My lg g3 has a problem where the sound goes from everything such as the earpiece, aux port, speaker and everything and the microphone doesn't work but sometimes the sound would come for like a minute or two then disappear again and no one knows about this problem can someone tell me what to do
    BTW I factory reset the phone about five times already and nothing
    02-07-2016 05:49 AM
  2. maclancer's Avatar
    I have the same phone and no issues here, looks to be a hardware issue... Does your phone is under warranty? I will suggest take it to LG support for them to fix it or replace it. Other than that, have you tried re-flashing the phone?
    02-07-2016 05:56 AM
  1. why my videos wont play on gallery on lg g2?
    By ccb in forum Ask a Question
    Last Post: 02-11-2016, 11:09 AM
  2. Somebody please enlighten me
    By Keithmufc92 in forum General Help and How To
    Last Post: 02-07-2016, 12:06 PM
  3. why my videos wont play on gallery on lg g2?
    Last Post: 02-07-2016, 06:41 AM
  4. Replies: 1
    Last Post: 02-07-2016, 06:39 AM
  5. Replies: 0
    Last Post: 02-07-2016, 03:27 AM
